Discuss Bal Sbr Or Weber Pr30 in the Tile Adhesive / Grout Advice area at TilersForums.com.
Wishiwasatoptiler
Points
1,108
Northeast
Hi
Need to restock on some primer, BAl spr or Weber pr360, is thee difference?
Over £15 more for bal so wondering if its worth using Weber
Cheers
J Sid
I use the Weber pr360 only because I use Weber adhesive.
I believe you should always use the primer recommend by your chosen adhesive manufacturer.
What adhesive are you planning on using?
Reply to Bal Sbr Or Weber Pr30 in the Tile Adhesive / Grout Advice area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
