Discuss Best tile adhesive? in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
Points
38
Suffolk
What's your tiling question? Pictures can be added.
I am tiling a bathroom three walls floor to ceiling.
The tiles are porcelain 600mm x 300mm.
What is the best adhesive to use and what thickness?
PMil07
Points
86
Sussex
Hello mate,
Personally I use BAL rapid fibre flex. I recommend a 7/8mm trowel, while flat buttering the back of the tile to ensure the perfect coverage.
Hope that helps
Points
83
Nottingham
If they’re porcelain I’d go for Ardex X77; brilliant for large-ish tiles. +1 for comment on trowel and back buttering. Are you applying a tanking solution to the walls or boarding out with a suitable backer board?
Kevbos
Points
443
London, UK
I would recommend mapei keraflex or keraquik !never had a problem with that adhesive !and it is great to use
Reply to Best tile adhesive? in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
