Discuss construction skills college/trade teacher wolverhampton in the Canada Tile Advice area at TilersForums.com.
Max@ableskills
hi i was wondering any info from anyone whos trained there or is planning o going on a 10 day tiling course i was also wondering do you need a nvq in tiling to get a cscs card thanks
Hi Sam. To get a CSCS card you do not need an NVQ. If you undertake and pass the CSCS test and hold no vocational qualification it will generate a site operatives CSCS card.
If you are looking to acheive a skilled worker CSCS card then you will need to have a vocational NVQ level 2.
Skilled worker CSCS card is blue in colour and states the qualification that you hold on the back of the card.
Good luck with your course.
Gazzer
And on most of the sites I worked on that wasnt enough to get you on site unless you were with another tiler with a skilled card. Its all down to the contractor and how strict they are with the rules.
Max@ableskills
Agreed.
Site operatives card is generally for a labourer or apprentice.
Blue skilled worker card is for a qualified tradesperson.
Max@ableskills
I thought a nvq in tiling would get me a blue cscs card as a professional trades person
It will but only if you have passed the CSCS test.
The NVQ and the CSCS test will give you a blue skilled worker card.
Also going back to your first post you will need to undertake a much longer/detailed course to cover all aspects of training required to enable you to acheive the NVQ whilst in the workplace.
College day release is one option over the duration of a couple of years or block release courses aligned with NVQ requirements.
AliGage
Subscribed
Just to reiterate what the others have said. Passing your CSCS test will not get you on site fixing tiles. Yet need to achieve a minimum NVQ Level 2 to get a skilled worker (blue) card. You won't achieve this on a 10 day course. Yes if you work for yourself you can be accessed but you'll be much better off trying to get employed whilst working toward your NVQ
Reply to construction skills college/trade teacher wolverhampton in the Canada Tile Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
