Discuss Damage Control - advice needed in the DIY Tiling Forum area at TilersForums.com.
Ravsta
DIY Tiler
Hi
First time on here, new to DIY and have my first challenge:
Decided to floor tile our first property and having done so with hardie backer boards and Lauara Ashley Dove tiles.
The floor had slight movement in certain areas, so we nailed down floorboards as secure as possible without me messing with the wooden beams below the floor. Also when tiling I decided to apply adhesive onto the back of the tile rather than the floor as I didn't want adhesive coming through the gaps (as wanted tight finish without grouting). Realized after it would look better grouting, so grouted it....(poor planning all round, not enough research done I know...never again will I make this mistake with DIY)
To cut the long story short having tiled and grouted, now some of the grout keeps cracking and coming out on certain tiles.
What do you suggest my plan to manage these tiles going forward ? Should I leave constant re-grouting, allow the tiles to break if they do and replace if they do ? or should I start ripping up the tiles which I really don't want to do.
Any advice here would be much appreciated - I can attach photos late if necessary
Full strip out and needs to be re done I’m afraid. Unfortunately with these things, we train for many years in subfloor preparation, tile fixing techniques and suitable products to use and that knowledge can’t be learned and applied easily on a DIY job. I’m not saying it can’t be done, it just takes a lot of research to do it properly when it’s not your forte. Pop a few tiles up and show us what you have. Sounds like a lot of movement.
Reply to Damage Control - advice needed in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
Bathroom floor. I would be grateful for advice on how to prepare my bathroom sub floor ready for tiling.I have removed the floor boards and plan to lay 18mm WBP plywood.The question is, what...
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
