Discuss Floor Has Tile Lippage, Wall Tiles Going Up In The Morning! Help Please! in the UK Tiling Forum area at TilersForums.com.
Time's Ran Out
Did you post your job on here or was the tiler recommended. As you've been on previously and you knew what you wanted I'd be surprised if you are going to be prepared to live with the issues you've mentioned.
Stef
Bal Rapid can be packed out to 12mm in localised areas but if the floor was flat then why is the bed that depth?
There is no way your grout lines should be out that much, its porcelanosa tiles, you dont get much better, Half a mm at most.
hope you get this sorted.
John Benton
Points
1,138
Leeds
I've fixed the Porcelanosa tiles 1m x 330mm rectified without any lipping on walls and they look great, and the wall wasn't perfect either. As Robson said a bit of localised additional addy may be required on non-perfect walls/floors. Really good quality tiles so there is no excuse at all.
Stef
John, if the tilers got lippage on the floor then what state are those big wall tiles gonna be in?
Those meter long tiles from porcelanosa are good to work with, a bit soft, but good all the same.
Points
476
any chance of some pics as that may help
Best i could do with the camera on my phone.
IMG_20120127_225300.jpg IMG_20120127_225421.jpg IMG_20120127_225445.jpg IMG_20120127_225516.jpg IMG_20120127_225519.jpg IMG_20120127_225541.jpg IMG_20120127_225814.jpg IMG_20120127_225819.jpg IMG_20120127_225842.jpg IMG_20120127_225908.jpg IMG_20120127_225914.jpg IMG_20120127_230003.jpg
John Benton
Points
1,138
Leeds
I dread to think and I bet he can't cut them lengthways either
jay
Thanks for the pics .and yes i can see why you are concerned .its not the best .maybe a pic of the whole floor might be beneficial
Reply to Floor Has Tile Lippage, Wall Tiles Going Up In The Morning! Help Please! in the UK Tiling Forum area at TilersForums.com
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
