Discuss Help! Tiled wetroom floor looks perfect but grout doesn't dry out! in the Australia Tiling Forum area at TilersForums.com.
The D
I must admit I hadn't thought that water could be coming from the walls...but if it was wouldn't we be seeing damp patches on the wall grout, too? These have not been replaced with epoxy, but dry out very quickly
I must admit on the one job there was signs on the wall but on the other there was no sign on the walls at all the water was just traveling through the adhesive and gathering at the lowest point. yours may not be the same problem but to be honest IMO grout will not let that amount of water pass through in a domestic shower without some serious cracks or pin holes. try cutting in to the grout on the dark patches and see if there is water trapped in that area.
Paula
This was the worst dark patch just after using the shower this morning: you can definitely see beads of moisture, plus the moisture on the tissue when I dabbed it. I am going to let it dry out and then run the shower hose directly down the drain and see if it returns. If not, we'll know if it is coming either from the shower valve or leaking from the waste, rather than somehow getting through the tiles. I'll let you know!
Paula
It seems it could be creeping in the adhesive bed... How is the drain sealed at the tile edges ?
This is how the drain is sealed: beginning to think now this may be where the water is creeping in? What do you think?
Can u take a hose pipe from shower head directly to the bath? That'll eliminate the shower head connector, the elbow behind the wall at the top of the pipe and the shower diverter all in one go or it will narrow it down to these three items hopefully.
Paula
Thanks for that. We have two shower heads (one fixed, one on a hose), with the diverter /valve away away from both. The bath is quite a distance away, so this is a bit tricky! But I see what you mean
Well if my thinking is right (anyone else feel free to object:D)
This should break it down to either a water feed issue or a drainage one. If u are able, maybe unscrew static shower head and fix a garden hose to it. I know it's faffing about but I'm hoping it'll break it down into two halves.
Paula
Yes, sounds sensible. But if it's not the water feed, then we'd have to work out whether the water is getting in through the tiles in the tray (perhaps around the drain?) or escaping somehow from inside the drain itself.Do you think this is possible?
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
It's possible I think yeah.
It's starting to get quite hard for us to troubleshoot because we're just winging it a bit here.
Do you think it's worth getting a plumber in to actually take a look. They see this all the time I'm sure. Or even a tiler, but I can't see how, until we've found out what's going on, a tiler can actually trace the leak if he's not a plumber.
By all means keep contributing to the thread and maybe we will pull this off for you. :D
But consider getting a plumber round! I'm sure this must be doing your tree in!
Well anything is possible, this is just a slight variation on what Geoff suggested, now I've read it :D sorry Geoff
But if u can take the water away from the shower and it reappears hopefully that should point to it being a problem on the feed side.
If not, it's either getting thro tiles during use, or the drain could be failing.
I'd leave it running a fair while in case it has to build up somewhere first.
Reply to Help! Tiled wetroom floor looks perfect but grout doesn't dry out! in the Australia Tiling Forum area at TilersForums.com
  • Sticky
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
