Discuss Primer G and masonry/brick wall in the DIY Tiling Forum area at TilersForums.com.
Hello
I've trawled forums and read the Mapei Primer G packaging etc but not sure I've got 100% comfort on this one and hopefully it's basic...
Is this product suitable for bare brick/masonry walls?
Most documentation seems to refer to plaster/plywood/screeds etc so just want to be clear. Essentially I am looking to prime the walls before bedding STS foam backer boards with keraquick (will also be adding mechanical fixings).
I believe applying 1:3 with water then a second coat 1:1 (or neat?) is the way forward but please correct me if I'm wrong.
Thanks in advance
Reply to Primer G and masonry/brick wall in the DIY Tiling Forum area at TilersForums.com
