Discuss Quadrant stone resin riser in the Canada Tile Advice area at TilersForums.com.
P19
Hi
im Attempting to raise my quadrant shower base. Probably going to use wood, though may use feet or both.
I’ve never done this before but am confident.
I just want some advice on fixing the base to the floor.
The reason being is because it’s downstairs and a porcelain tile floor.
I’m concerned with my inexperience, even with the correct drill bits and tools, I may crack a tile, screwing wood or even legs to the floor.
Are there any adhesives you recommend that would suffice the job? Or should I just go ahead and try and not break any tiles
thanks for your help
Reply to Quadrant stone resin riser in the Canada Tile Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
