Discuss Replacing Existing Floating Floor in the Canada Tile Advice area at TilersForums.com.
jmm
I’m looking to lay porcelain tiles in a kitchen diner (~22m2). I have a floating floor, which is not suitable for tile. I’ve been quotes for Ditra, but Ditra is for horizontal movement. My current sub floor is:
- Bison Block and Beam.
- 20mm insulation
- DPM (blue plastic sheet)
- 18mm WBP tongue and groove
full
I’m planning on removing the WBP, DPM and insulation. And I don’t know if there is a DPM under the Bison.
I considered a bounded screed, but this is likely to be 40mm thick with no insulations (too cold). I only have 55mm from the Bison to the top of the tile.
So I’m looking to replace it with:
- Ardex DPM 1 c (just encase)
- Marmox 40mm Multiboard with a flexible adhesive.
- Ditra
The Marmox (and Ditra) will form the vapour barrier to protect the tile.
Would this subfloor take tile? Does any see any problems?
Many thanks
jmm
I also expect the block and bean to be suspended but I'm removing a DPM and feel I should put one back.
I've not considered UFH. Prefer to use the extra depth used by a UFH system for insulation and to ensure the floor doesn't move. I still like the idea of Ditra to create a vapour barrier and protect against horizontal movement. The room is 6m x 3m. So...
- Beam and Block
- Ardex DPM 1 c
- XP Pro Board
- Ditra
- Porcelain tiles
I would still use a flexible adhesive to bond the XP-Pro to the DPM and therefore ensuring its not a floating floor. And that the XP-Pro will not create a cold bridge?
J Sid
- Beam and Block
- Ardex DPM 1 c
- XP Pro Board
- Ditra
- Porcelain tiles
XP-pro boards need priming on all sides and can then be stuck down to make a none floating floor.
If you use the Ditra as a vapour barrier tape the joints
jmm
With the Ditra I was considering using waterproof points both on the floor and up the walls (just behind the skirting boards). This would be like how my DPM is currently fitted.
Would not prime the floor rather than the board? I was thinking about using Ardex P4 primer on the DPM.
jmm
take up every thing, tank out floor or apply 2 coats of sbr 1st coat 1/3 2nd coat at 90 degrees to first coat 1/1
leave to dry stick down 20mm wedi board lay another layer of 20 mm wedi at right angles to the 1st then tile on top. easy peasy.
What's the benefit from using two boards over 1 40mm board? Is this to remove the lateral movement or part of the waterproofing?
And are you suggesting wedi board to remove the need to prime the boards?
Just Rizzle
by using 2 layers you strengthen the floor as your effectively laminating it and by using wedi better water protection and also no priming so job can be done faster.
Tile Shop
The wedi is pretty strong. one single 40mm would be fine on rigid block and beam. Unless you weigh approximately 2 tonnes, then you may get a tiny bit of compression! Based on wedi's technical sheet.
Thats if i've got my rough calculations right.
Compression resistance of 0.25N per mm2 with the average adult foot has an area coverage of 31000 mm2 multiplied by 2 feet (in most cases) = 62000 mm2...... times 0.25N per mm2 = 24800N dead weight multiplied by 0.1019kg's per Newton = 2528 kg with both feet firmly planted although results may vary for walking, jumping or standing on one leg.
Ok, so I was half a tonne out! and thats if you're standing on the bare board. once its tiled, it'll spread the weight even more. Meaning you could burger yourself up to 10 tonnes. maybe more!
Would recommend this floor preperation to feeders!
jmm
I doubt that I'll be putting 2 tonnes on the floor (even with a quartz kitchen worktop). So I'm now going for...
- Beam and Block
- Ardex DPM 1 c (2 coats of sbr 1st coat 1/3 2nd coat at 90 degrees to first coat 1/1)
- Ardex P4 primer
- 40mm Wedi Board
- Ditra
- Porcelain tiles
- DPM plastic sheet on the walls
Does anyone disagree with this?
And can anymore recommended the flexi adhesive to stick the wedi down (should I keep with Ardex)?
Just Rizzle
the reason for using 2 x20 mm boards is this from my experience of kitchens the chances are you will have a load of pipe work running over the floor between the insulstion. the first layer you would run up to the pipe work and between it . the second layer at 90 degrees to the 1st bridges these gaps it also allows you to level the floor if the sub floor is uneven by using wedi there is no need for ditra as it effectively decouples and waterproofs so no need also for dpm plastic up the walls as the tanking takes care of that. I have done a couple of floors were ive used this method and done them both in a day.
another way would be to rip up floor cover with a dpm then screed out with 40mm semi dry screed and bed the tiles in using cement sbr slurry that's the way I would of done it 20 yrs ago and again all done in a day:)
jmm
I have 4 pipes: 1x water, 2x waste and 1x capped gas. The two board solution is interesting. Ideally I want to lay the least amount of board possible (i.e. once at 40mm). But this will difficulties around the pipes.
DPM on the walls too instead of a plastic sheet then.
Removing the need for Ditra would save several hundred pounds. I guessing the foam acts as the decoupling between the two backer boards.
Given the price of Wedi, would going back to (cheaper) Marmox board do the same job? The specification seem very similar (if anything the Marmox seems stronger).
Just Rizzle
ive never used marmx so cant comment but if there like wedi ie water proof then yes
jmm
Seems to be a similar spec but half the price. So finally...
- Beam and block
- Ardex DPM 1 C
- Ardex P4 primer
- Ardex x7G Plus adhesive (C2)
- 30mm (or 20mm + 10mm) Marmox board with fibre tape
- Ardex x7 Plus adhesive
- Tile
bcd-87
Are you the tiler of the home owner ?
Reply to Replacing Existing Floating Floor in the Canada Tile Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
