Discuss Sealing & Grouting Riven Slate Floor in the UK Tiling Forum area at TilersForums.com.
L
lovin' diy
I have just finished laying a black riven slate floor in the kitchen and according to the company I purchased it from I have three tasks remaining(!) - in the order suggested : Colour intensifier (Lithofin), grouting and Stain stop (also Lithofin).
A few questions :
I have taken care to keep the slate clean as I have laid them, using a sponge and water, and there is no adhesive on the tile surface now. However, when the slate dries, you can see the wipe marks left by the sponge. Do I need to keep cleaning until this is removed - if so, any tips! - or will this be masked by the colour intensifier etc.
Any tips for effective grouting?
Any tips for applying intensifier/stain stop?
Thanks for your help - already picked up some great tips from exisiting posts!
kilty55
edinburgh
hi mate just done an identical job using lithofin
i wash the slate using clean water and 1 continual sweep of the sponge,,wash sponge after each sweep and change water as soon as it gets cloudy this will help these3 dried in brush marks left which i have found are caused when using not so clean water.
once it has dried i applied lithofin colour intensifier using a mini roller...also apply a decent amount as i also find if your too heavy with the roller and not enough liquid it can leave roller marks on the slate..allow to absorb..any puddling of intensifier left after mop up with a cloth or kitchen roll..once dried same again with the stain stop allowing the stone to absorb what it wants and remove any excewss again at end..hope this is of use and good luck:thumbsup:
kilty55
edinburgh
i think you can also get lithofin stain stop plus which is intensifier and stain stop mixed but have never used it,,may save you some time:thumbsup:
good quality sponge also will make your job easier..cheap sponger get ripped up by slate i also find and i use a toothbrush for removing grout from the natural crevices in the slate
Reply to Sealing & Grouting Riven Slate Floor in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Sticky
  • Question
