Discuss Sealing porcelain tiles in the Canada Tile Advice area at TilersForums.com.
Tile Fix Direct
TF Official Sponsor
153
733
Aldershot
Could be a few issues. Sometimes a fine residue can be left on tiles after grouting. This can sometimes be visible or more often it is not. If visible it is likely to be a cement residue with polymers. If not easily visible it may be polymers from the grout. To clean off polymers you need to use a dilute alkaline cleaner like Lithofin Intensive Cleaner. Make sure you follow the instructions exactly as written, in particular the dilutions. If grout residue is a problem then use Lithofin grout remover followed by Intensive cleaner. Of course, it could just be that the tile is a glossy light colour which shows dirt more easily than a darker matt tile.
Dumbo
Porcelain by it's nature is not a porous material . Do you mean it is textured , or if it's a polished porcelain sometimes micropores can be opened up during the polishing process . Most factories seal the tiles during manufacture , some of the cheaper diy outlets tiles are not sealed or if you use a steam mop you can remove this sealer ..
What is your tile type . Do you have any pictures
Indi
London
the tiles have a slight shine
Reply to Sealing porcelain tiles in the Canada Tile Advice area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old...
