Discuss Show Us YOUR Work Thread - Tilers Pictures in the UK Tiling Forum area at TilersForums.com.
Status
Not open for further replies.
The Legend; Phil Hobson RIP
Nice work Mark, sorry I could not join you, maybe next time.:thumbsup:
ishi69
Points
503
Warrington Cheshire
Lovely stuff. Are the as slippy as they look? They look really shiney!
A few pics of the floor when dry. ImageUploadedByTapatalk1339009927.348697.jpg ImageUploadedByTapatalk1339009949.923112.jpg ImageUploadedByTapatalk1339009975.963458.jpg
rainsco
nice joints in the slope. do you cut all the small tiles?
yesterday i fixed only 9 tiles on a long day. it was not easy. the tiles have 14mm thickness and i have to calibrate the shower to one tile in the wide. and the alurail for glaswall later has to resessed. so i used ardex x32 because it can be used until 30mm mortar bed. (75kg for 9 tiles!!!) i floatet with a 15mm middlebed trowel and buttered with 10mm. sometimes more and sometime less. i take the tiles with a double sealed vacuum handle. without this tool it wasn´t possible to carry the buttered tiles alone in this height. it was mental not easy to trust this tool.
demotivating moment was when i set a tile and knock it with the hammer the edge touch another edges and "zack" a glaze springs away... so i later just knock it when i space them with the wooden wedges. on the tool pictures you see my custom made wet saw for perfekt long cuts until 220cm. i test the dry cutting with my 120cm kaufmann cutter and it was ok but it was not save brackage on the end. so i decided to use only wet cutting. it takes more time (15l water for 1 tile needed) but it is 100% safe and the edges are perfekt. for this projekt i bought a new drilling machine. my other one is limited on 40cm wide. for the 45degree cuts in the niche i use my little wet saw. crazy, such a machine park for only a shower!
ishi69
Points
503
Warrington Cheshire
Hi rainsco, all the small tiles for the wet area have been water jet cut. Your latest job looks like another nice project. What size are the tile 800x800mm ?
Tony73
Points
1,233
acton w3, london
DSC_0319.jpg DSC_0313.jpg DSC_0314.jpg DSC_0315.jpg DSC_0316.jpg DSC_0317.jpg DSC_0318.jpg
Here i have finished stage one: tiling and grouting. floor 400x600 slate tiles with mapei antracite grout, walls 300x600 calacatta marble tiles with mapei silver grey grout.
Stage two to come: template and fit 20mm carrara bath top with splash back and vanity top :hurray:
mattle40
Credit to you pal, your work is pure quality from design to completion,
That's the result of really enjoying your trade
Status
Reply to Show Us YOUR Work Thread - Tilers Pictures in the UK Tiling Forum area at TilersForums.com
I spend some time in doorways. NOTE THAT DAN HAS CREATED THIS NEW 2024 SHOW US YOUR TILE...
