Discuss Show Us YOUR Work Thread - Tilers Pictures in the UK Tiling Forum area at TilersForums.com.
Status
Not open for further replies.
jonnyc
110.jpg 107.jpg 111.jpg 112.jpg 118.jpg 119.jpg 121.jpg 124.jpg here are the french antique terracotta tiles we are laying now.
i sorted through the whole six crates which took 3 days to grade in to 3 sizes .
the reason for this is that we need to get a good mix of all sizes so that the joints dont get too big or small.
also we found that there wre layers of different tiles reclaimed from different houses in different crates and needed to blend them all in.
to keep the floor from snaking and turning out of square with all the odd sizes, i take the average size tile of say 160mm and add 5mm for joint. i then mark square boxes on floor that are the size of six average tiles and joints.
it turned out i had 50 percent average of 160mm , 30 percent of 155mm and 20 percent of 165mm.
so in each box of 36 tiles we had 18 of 160mm ,11 of 155mm and 7 of 165mm.
one of the guys fixes a tile level in each corner of box and works his way up and down room.
the others loose lay the other 32 tiles in a box to check they lock in and fit before fixing.
it takes quite some time to keep turning tiles round to get them to interlock as many of the tiles may be 165mm one way and 155 the other way or 150 one way and 160mm the other.
when box looks fairly straight from both angles we simply bed tiles between corner tiles and they are automatically level.
the thickness varies alot from 15mm to 30 mm so it is easy to bed tiles between corner tiles adding more or less thickbed adhesive for each tile.
the more experienced of my guys who have probably laid over fifty of these floors would sort and lay 5 sq mts in a day.
we need to fix each box in a time span when all tiles can move as when box finished we move some of the edge tiles to box inside of chalk line or over so that you do not see a straight line grid when boxes are completed.
this is method i came up with over 15 years ago when i fixed my first old terracotta floor and got in a right mess.
the other advantage of laying a tile in corner of boxes is that many times i lay in sand/cement and adhesive in quite a thick bed .
i did a huge one in israel of about 500 sq mts and every room had diagonal tiling within grid pattern boxes and laid sqaure on outside.
i was able to set out tiles on corners of these bay grids and my other guys just had to fill in between and not even use a level just a long box section straightedge. i had them starting in different rooms at same time so we could make sure the tiles were evenly distributed in all rooms . otehrwise i would have had to go through 18000 tiles before we could even start.
you will see from photo that big variance in colour at moment but this is because some are much wetter than others and probably take about 3 weeks to dry before can seal and grout with washed westerham sand and white/gryey cement grout. then waxed.
you have a very good tile shop near the eisar river in munich not far from you that i have visited. they specialize in old reclaimed terracotta and stone and you could get very good work from them rainsco.
i will look up the company name for you if you like this tyope of work.
another great job from you again.
we will be doing the next room next month laid on diagonal and double border. this will be connected to kichen tiling now by terracotta steps
rainsco
hi jonny,
the smaller joints looking way better....!!!!!!
i allways try the smalles joints but on this floor the size of the entrance floor and the alu-frame decided the joints. and i thought in history they were laying with bigger joints..
i sorted the diffrent sizes while laying. i had 6,5qm and the room is 5,3.
the material came from Habitarte* - Historische Baustoffe - Home
i think 50% were used tiles and 50% looked a little fresher. and the new one are thicker and harder to cut. not cheap material!
your mix is very nice. have i really 3 weeks to wait to groat the tiles? i used no fast adhesive. is zement-sand the best joice? wich grain size do you recommend?
Tony73
Points
1,233
acton w3, london
So yesturday i did some work in my garden. floor was done some time ago, but was fixim porcelain tiles on walls and carrara marble on top. Got up 6-30 this morning , grouted marble joints and washed floor.
jonnyc
how long it takes to dry really depends on how wet tiles are.
the reclamation yards in france often have to clean off a lot of red paint on top of tiles.
sometimes they do this with paint stripper or pressure washer.
the french used to paint their terracotta withthis paint just like we used to in uk with red cardinal paint over quarries .
i would get a dehumidifier in as soon as possible and block offf the door to make air tight. i also use an air blowing machine which i leave on with dehumidifier . it greatly increases drying time.
will try to find a link for for one of these.
it is one of the most useful tools i have ever bought, especially if i am cleaning a stone floor and want to reseal same day.
washed fine grain render/plaster sand with white and grey cement mixed to proportion to give colour you want looks far better than grout.
some people mix sand with the grout but i dont think this looks very good.
dont know what clour sand you have in your part of bavaria.
fast set adhesive no good when laying this sort of tile as need to adjust joints when areas layed.
you probably have two different batches of tiles from different places and the wear on top is different.
the difficult thing is trying to get a reasonably even finish on rough and smooth surfaces of tiles.
cant use wax in bathroom as will go white if gets too wet.
i would look at lithofin products.
thier classic wax forerracotta is very easy to apply and buff
like the look of that habitarte, i dont rember seing that when i lived in munich.
they used to put a huge marquee tent up in the summer near the nyphenburger palace where hundereds of bacpackers could sleep very cheap.
i lived a whole summer there once . the stone shop i know is not this one.
Colour Republic
Jonny your work makes me sick!!! damn you, everything you do i'm jealous of.
Status
Reply to Show Us YOUR Work Thread - Tilers Pictures in the UK Tiling Forum area at TilersForums.com
I spend some time in doorways. NOTE THAT DAN HAS CREATED THIS NEW 2024 SHOW US YOUR TILE...
