Discuss Spacer and adhesive in the Tile Adhesive and Grout Advice area at TilersForums.com.
Nearly there ... sorry for all of the banal questions. .... two more though!
1) I’m using a 250x400x7mm glossy tile. Do I use a 2mm or 3mm spacer? It’s a small en-suite room.
2) will this adhesive be ok? (see pic). The instructions say it’s good for 300x600 but I know that larger tiles may require a mix-yourself adhesive. If not, is there one I can get from a major diy shop which will be ok?
Thanks again!
Reply to Spacer and adhesive in the Tile Adhesive and Grout Advice area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Tile Adhesive Trending Topics
Tilers Forums on FB
