Discuss Tanking price in the Tanking and Wetrooms Forum area at TilersForums.com.
L
LM
If it's fitted correct then it would be ok but I find the plumbers leave too much silicone on the top edge & leaves you with a lip at the bottom of the tile.
I don't find that an issue, maybe because I've explained to all the plumbers I work with exactly how I want the classi deal fitted and so far so good:)
One Day
Boarded and waterproofed in about 4 hrs (photo shows not finished).
I charged a lot more than 200quid for the prep though!
Points
1,098
Somerset
I charge £50 above a bath and £90 for 3 sided shower for materials. Labour is £40 for a bath and £60 for shower enclosure walls. I personally prefer to install Marmox boards (and Marmox waterproof tape for joints up to 1.2 metres above bath/ tray). Favourite tanking kit currently is Tilemaster, but it depends where I buy materials, regularly use BAL and Ardex systems.
Stef
I've not been that lucky, I had to cut one out as it was sticking out the wall about 6/7mm
F
Flintstone
Half 8, prime it, cut the tape to length, by 9 your tanking, half 10 your out the door
H
hmtiling
Some tanking kits specify 2 coats and for the first coat to be touch dry, so 4 hours is about right for that. 2 hours about right for one coat.
F
Flintstone
I use tilemaster kit and that's a 2 coat job, first coat dries to touch within 10 mins! Not sure about other brands
Stef
That is Mapegum & you couldn't do it in 2hrs as you need to wait till the 1st coat is dry.
I never go to a job just to tank a shower, it's done in conjunction with other jobs.
John Benton
Points
1,138
Leeds
Tilemaster is 4 hours before tiling so tiling in 2? I wouldn't do it personally. I try to put my 2nd coat on last thing so I can start tiling first thing next day.
Points
1,098
Somerset
Yes, if at all possible. I usually fit this to the prep day, or floor tiling day. In a whole bathroom tiling, you can do at least 2 walls to fill in the rest of the day.
F
Flintstone
I never said you could tile it in 2, I said it would take two hours.
I always tank the day before
Reply to Tanking price in the Tanking and Wetrooms Forum area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
