WetSaw
Not sure. I remember when I was with you the same happened when cutting out Tv niche ?
Did they just buy a bigger telly and Marc blagged the original one?
Discuss This will be a long tiling job !!! in the Australia Tiling Forum area at TilersForums.com.
I wish!Did they just buy a bigger telly and Marc blagged the original one?
Apart from how much to value a project at, that’s probably the most difficult question there is to answer.Who pays for the new pieces if they are unusable after a fracture etc?
To be honest, I don’t actually recall that incident on the tv nicheHow convenient!
Just a thought . I don't know if it was possible. But maybe if you had drilled a small hole at the end of the fracture it may of stopped it by dissipating energy around the circle rather than just at one point .Katrina, bless her is discovering the best way to mitre as it is a bit of a stretch sometimes. We cut the niche out on the table and it fractured. The more we tried to mitre the more the fracture went. Bit the bullet and cut another 25mm off, problem solved
Reply to This will be a long tiling job !!! in the Australia Tiling Forum area at TilersForums.com
