Discuss Tile face up or down when using grinder in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com.
acaciaguy
Points
558
Warwickshire
Hello all
When using an angle grinder with a tile cutting blade on, do you cut with the tile face up or down.
Do you want to have blade cutting into face ?
Sorry if this is a stupid question.
Time's Ran Out
No such thing as a stupid question ( but it’s close)!
Glaze surface up so your cutting through the glaze and make sure you put the blade in the grinder correctly so it’s cutting in the direction of the arrow.
Now if I’am cutting a hole in the tile I do cut on the back and punch the hole out the front.
acaciaguy
Points
558
Warwickshire
I thought that. Same as cutting into laminate wood etc. What about with porc? Glaze dependent again I guess?
Stupid question number 2 - arrow on grinder matches arrow on blade?
I
Italy
and punch the hole out the front....;(
Waluigi
The arrow on the grinder blade must match with the direction that the grinder spins.
Usually the arrow side out. It is on my grinders/polisher anyway.
acaciaguy
Points
558
Warwickshire
Thank you. I don’t normally have a problem. It’s been a long day and I have been playing with my new disk and cutting guide - which has messed with my head a bit lol. It will all be obvious tomorrow when I look at it again and I will feel like a bit of a ... wally
Reply to Tile face up or down when using grinder in the Tiling Tools | Tile Cutters, Trowels area at TilersForums.com
Currently using TX700N but obviously now too small for the 1200x600mm I'm increasingly being...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
