Discuss tiling over paint in the UK Tiling Forum area at TilersForums.com.
smokey1234x
i have done loads of jobs in bathrooms were the complete bathroom is painted.most of my customers supply the addhesive grout etc.to tell the truth i hardly ever even look to see what type it is.but reading some of these threads its starting 2 make me think twice,is any1 else in the same boat
L
Leatherface
I ALWAYS...........
advise the customer that the paint has to be sanded - this is to give the tiles and adhesive a good key to the wall - look at removing at least 60 to 90 % of the paint dependant upon how heavy the tiles are.
I have a variable speed grinder with velcro sanding pads - makes light work of the job - although very dusty ( allow a full days labour for an average bathroom )
Just to note - imagine sticking a piece of sellotape on an imulsion painted wall and then removing it after a few hours !!!!!!!!! - the paint comes off on the tape, well that's what's gonna happen with the tiles, the adhesive stickes to the paint and not the wall !!!!!!!!!!!!!!
BEWARE
smokey1234x
well that makes sense,but what am really asking is does any1 else tile over paint as i do
tiler tom
I check the soundness of the paint ie. it is not loose and flakey and score through to existing. Difficult thing is telling the customer the incresed work in guarenting a sound finished result when Joe Bloggs follows you up with no problem and for x no of pounds less.
Nice change of picture Leather you look less a mass murderer now with your new hairstyle.
penno
No i don't tile over a solid bed of paint, have tiled over paint but have give it a good score and a good rub with a wire brush first. Remember if you tile on paint then it is basically the paint holding the tiles on, could quite easily fall off (and probably will.
L
Leatherface
Thought I had answered your question mate - yes I will tile over paint - but only once it has been sanded - the amount of sanding required depends upon how well the paint is keyed to the wall and how heavy your tiles are .....
100mm x 100mm biscuit tiles, a little sanding required
600mm x 400mm travertine - a lot of sanding required
Scoring in my opinion makes no difference if the paint is emulsion or flaky - just makes it more likely to de-bond from the wall !!!!!!!!!!:thumbsup:
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
He'll tile over the sanded paint then.
Emulsion breaks back down to a wet paint (sort of) when it comes into contact with moisture. Which is why if you lick your finger and rub it on an emulsion painted wall your finger will get paint on it.
If you get paint on your finger, you need to be scoring the walls to get a good key.
Imagine if your tiles fell off on somebody in the bath, and imagine if they were really young, a child perhaps and it seriously harmed them. You're hitting them on the head with the weight of tiles and adhesive and grout in god only knows what sorts of quantity. The whole wall could fall off.
L
Leatherface
dan
sorry, scoring in some cases makes sod all difference !!!!!!!!!!!!!!!!!
If the emulsion paint is not adhered very well to the wall, the wall needs sanding, no doubt about it.
i have seen walls that have been emulsion painted onto fresh plaster where the whole wall of paint just peels off with little or no effort !!!!
brian c
Leatherface you will find this out that there are a lot of newbies and sometimes it is hard to get your answer over as i have also found,eh tysfoot.lolscrew it tysfoot m8.psml.
Reply to tiling over paint in the UK Tiling Forum area at TilersForums.com
  • Sticky
