Discuss Training for tiling students in the Tiling Courses area at TilersForums.com.
rmcwil
Points
36
benfleet
Does anyone know of any material that can be used as a training cement for tiles. I'm looking for something that has the same consistency as tiling cement but does not set and could be reused. I have been told that there is a builders caulk that you can get in a tub that can be used. I just need to be able to put the tiles up and then remove them again to reuse.
Points
58
San Jose
Try bucket pre=mixed adhesive. It sets slowly and is easitl scraped off next day
Does anyone know of any material that can be used as a training cement for tiles. I'm looking for something that has the same consistency as tiling cement but does not set and could be reused. I have been told that there is a builders caulk that you can get in a tub that can be used. I go to https://edubirdie.com/do-my-homework to do my homework. I just need to be able to put the tiles up and then remove them again to reuse.
Yes, bucket pre-mixed adhesive can be used as a training cement for tiles. However, have you tried mounting putty? It is also non-setting and can be easily removed, so it's ideal for training.
I usually use DAP DryDex No More Nails Mounting Putty, it's water-based. And Loctite PL 300 Premium Construction Adhesive. This product is a high-strength adhesive that is also non-setting. It is ideal for attaching tiles to uneven surfaces.
A little lifehack that I got: apply a thin layer of adhesive to the back of each tile.
alice james
Reply to Training for tiling students in the Tiling Courses area at TilersForums.com
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few...
