Discuss Warmup dcm pro heating in the Tiling on Underfloor Heating area at TilersForums.com.
Mark Frost
528
Aylesbury
hi guys I use warm up dcm pro all the time. the self adhesion is increadle on how it works. it's the easiest ufh to use and it's quick. the adhesion actually gets stickier over time and once it's warmed up the glue gets better. it's great stuff and just trust it. I love it and it's doesn't cost as much as the others on the market. hope I've helped you on trusting it at first I wasn't sure but I've used it and not had a problem
Lee T
38
dorset
Do you Need to prime the floor prior to sticking the matt like water guard? Or not?
Andy Tiler
1,043
manchester
Yep same for me Warmup DCM PRO the quickest to install makes my life a lot easier top product
Albert
1,253
Gateshead NE8, UK
It’s a product I’m still not sure on, it comes at a premium price compared to other similar systems which you stick the mat down with adhesive but it goes down quicker. Your relying totally on the thin layer of glue for the whole job, and the castelations aren’t tapered just straight so not sure how the adhesive locks in?
I think with this system you have to self-level, unless i am
reading the instructions from your link wrong
Andy Tiler
1,043
manchester
After using hundreds of mtrs Albert i would prefer to self level over the matt. with levelling compounds now setting in 45 mins its a doddle.. if ever a tile needs changing and easier see your chalk lines when setting out
Bopster
563
Colchester
Thread resurrection time lol
I installed loads of warmup before but not the mat system. Kitchen I’m doing in the new year will have this type of system over a concrete slab with porcelain tiles. Height increase will be critical, obviously 10mm insulation boards set in flexible adhesive on the primed slab would be better but will 6mm boards be enough? I’ll Slc ontop of mat before flex adhesive and tile
Lou
Admin
1,473
Staffordshire
Reply to Warmup dcm pro heating in the Tiling on Underfloor Heating area at TilersForums.com
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which is very thick concrete. He wants electric underfloor heating but I'm concerned he'll lose too much...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
