Discuss What Do You Use When Polishing Porcelain Edges? in the Australia Tiling Forum area at TilersForums.com.
Just Rizzle
i have a set of diamond polishing pads they do the trick no problem also good for limestones and marbles 80 grit to 1200 grit
can also be used for doing your nails if you want:D
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
Now the only word in that sentence that would impress me more is carbon. But you'd just have tourettes if you whacked it in there mid-sentence because I'm pretty sure there's no carbon involved.
Just Rizzle
did I say I did the graft my son who is my partner dose the polishing I just check it , if its not correct he dose it till its right they have to learn.
Dan
Admin
Staff member
Points
1,318
Staffordshire, UK
I still "drill holes" with a pin hammer tile nippers because it takes skill. Doesn't matter what the tile type is or the size of the hole. I'll get it as perfect as a drill, first time, every time.
So I see your point pal. Can't beat the hand machine, of, well, the hands.
Reply to What Do You Use When Polishing Porcelain Edges? in the Australia Tiling Forum area at TilersForums.com
  • Article
123 Year Old Johnson Tiles Factory to Close Down Causing 110 Job Losses 123 Year Old Johnson...
