What tile cutters do you use?
Dan
Admin
Generally the Rubi name is used when you talk about tile cutters but maybe you trust a different brand?
No where to put name of cutter Dan. I use a Montolit Masterpiumer 63 and a little £25 montolit. 63 is brill for repetative cuts and will cut porcelain marble and granite (with a bit of help with mallet).
have a mini monterlit and master piuma
like grumpy grouter I have a £25 mini montolit great for most bathrooms where space is a premium and a master piuma 63 for the larger floor tiles. Find the breking system on the 63 great no broken tiles. The 63 also suits me as it is set out for a left hander for some reason although the mini can be a problem sometimes. Some say that it is difficult to use because you cant see the blade but you get used to lining the cut up with the breaking spine. Also being able to set the mitre cuts time. Have used the rubi but i felt it was not as substantial as the montolit as it has flexible hollow tubes instead of the sturdy centre bar.
sigma 620, had it for 12 years, had a ts40 rubi before that in fact still got it, but the sigma is the one
Plasplugs Compact Plus Diamond Wheel wet cutter & Plasplugs Powerglide Flat Bed dryTile Cutter.
So far they have done me fine, on my 3rd job using them now, cheap n cheerful but so far haven't had any problems.
Dan,
Dan,
Dan,
Dan,
