BTB
Hi
First post, although been lurking for quite some time.
I do a reasonable amount of tiling (though don't make a living from it like you guys), up to now has always been ceramics with tubbed adhesive (mostly bathrooms when we do a full re-fit).
Anyway, customer has chosen a 600x300 porcelain for the latest job (they actually get 20m of them free with the suite they have bought, so the quality will be dubious no doubt).
They are not that heavy (have used heavier ceramics), however I do know that I need to use bagged adhesive.
The thing is I don't like the idea of rapid set and the possible wasteage if I can't get the tiles on fast enough (I know I can mix bits at a time but seems like a real pain).
So.....
Is there a bagged adhesive which will do the job nicely without setting too quickly and can I just use normal grout with porcelain?
Also, the same tiles are being used for the floor. Can the same combination of adhesive/grout be used (I will be plying the floor first naturally).
Many thanks for any help
BTB
So.....
BTB
