Porcelain floor tiles
L
lewisloo
Hi
I have just finished my kitchen and the floor is the next project, I have layed 18mm ply over the orginal floor boards and bought the tiles (porcelain floor tiles), in my haste I picked up a couple of tubs of adhesive and grout for wooden floors, it wasnt until I got home and read the tub and realised this is not suitable for porcelain floor tiles, now im stuck on what to use, having looked on the B&Q website there is a unibond cement which is suitable for porcelain tiles, is this the best option? ,and can I still use the tubs I have bought for grouting? any help will be much appreciated
many thanks
p.s can a grip and fill adhesive be used?
Don't think it's good idea to tile straight on to ply, I would still glue and screw hardibacker, 6 mm will do it if floor is not bouncing, other option is to use uncoupling membrane
I agree with Dontiler. Also I wouldnt bother going to B&Q for the adhesive, Is there a Tile Giant near you? If not there must be a topps. Go in there and talk to the guys in there. If its Tile Giant it will be Mapei (my personal fav) or if its topps it will be BAL. You will want 6mm backer board like no more ply or Hardie (provising there is no deflection in your floor) and a single part flexible cement based adhesive. I would take the fix and grout back to the shop and pick yourself up some suitable floor grout from said suppier. Might work out slightly more money but I promise you it is worth it. :thumbsup:
Why not tile onto 18mm ply overboarding? Sounds pretty good to me as it is.
Only point I would make is to check the adhesive you use doesn't recommend you seal the underside of the ply, like BAL.
I dont like tiling on to ply given the choice, tile backerboards are designed to be tiled onto, ply is not.
  • Ply will swell with moisture, this can cause tiles to lift or grout to crack
  • If ply get damp but not enough to lift tiles, it can stain the grout
  • A lot of ply is treated with fire resistant chemicals that stop the adhesive bonding
  • Most ply is NOT suitable to tile onto
Backer boards will do none of the above.
Best Floor Tiles
lewisloo,
Richard Edwards,
lewisloo,
Richard Edwards,
