Procedure: Wall tiles or floor tiles first ??
Hi & welcome,
I prefer to do the walls first, as all your mess and overspill will land on the floor :thumbsdown:.
As per APH, put the bottom row in to finish.
However, in summary there is no right or wrong way, it is all down to personal preference and site conditions.
It is the end result which matters...
here my tilers do the walls first then rais the floor level and tile the floor.
The result is that none of the floor tiles can be slipped under the wall tules and the grout is visible whe you look down, so looks untidy.
I think much better to have the floor tiles slipped under the bottom layer of wall tiles.
But as I said earlier I live in LOS Thailand and they are very fixed in their ways .
Many Thanks,
H69
Could you not run a silicon bead around the perimeter of the floor where the wall and floor tiles meet to make it look tidier and hide your cuts bud
Yes I think a good idea , I will get them to do that.
The grout I used is grey which looks good except along the walls so a White silicon beading will be good.
Many Thanks
or even a grey silicon (if you can source the same colour as the grout) would make it look much tidier
Best Floor Tiles
hasher69,
Mouldy,
hasher69,
Mouldy,
