Gazzer
Yes correct. You shouldnt add any additives to already modfied adhesives or grouts.
my apologies, i thought that ditra did help with vertical movement.
here's a link that you may find helpful in making your mind up all the same.
http://www.tilefixdirect.com/pdf/Schluter-Ditra-Matting.pdf
Well money is always an issue, but this sort of mistake can be soooo expensive so it's a case of getting to the point where 'better safe than sorry' meets 'if you have a decent belt then you really don't need those braces'if its not a money issue
Absolutely. Last chap in said he always overboards floorboards with 18mm ply, but my 22mm T&G boarding is so much better than floorboards he was confident 12mm overboarding appropriately fixed would be fine. And he walked the floor.none of above will help with vertical deflection , but strengthening the floor as much as poss will
