Discuss Show Us YOUR Work Thread - Tilers Pictures in the Tiling Work Showcase Forum area at TilersForums.com.
Status
Not open for further replies.
Dave
Subscribed
389,894
1,000,000
Co.Durham
Be it from installing a kitchen to garden decking. Show us your work! Get those pictures taken, but then do something with them! Actually add them to a thread and some facebook groups with your website link in them etc and it'll help spread the tile love. :)
AliGage
Subscribed
I would usually undercut and remove skirting. But, this is literally a brand new house. The young lad was on a bit of a budget and keen to move in asap. So it was Durabase and as neat aa i can on the cuts.
Got the bathroom and en-suite floors to do. Removing basin and ped as well as WC in them. Seeming as the splashback tiles don't take much getting off.
Just a few pics of the job I'm just finishing up.
R
rainsco
nice joints in the slope. do you cut all the small tiles?
yesterday i fixed only 9 tiles on a long day. it was not easy. the tiles have 14mm thickness and i have to calibrate the shower to one tile in the wide. and the alurail for glaswall later has to resessed. so i used ardex x32 because it can be used until 30mm mortar bed. (75kg for 9 tiles!!!) i floatet with a 15mm middlebed trowel and buttered with 10mm. sometimes more and sometime less. i take the tiles with a double sealed vacuum handle. without this tool it wasn´t possible to carry the buttered tiles alone in this height. it was mental not easy to trust this tool.
demotivating moment was when i set a tile and knock it with the hammer the edge touch another edges and "zack" a glaze springs away... so i later just knock it when i space them with the wooden wedges. on the tool pictures you see my custom made wet saw for perfekt long cuts until 220cm. i test the dry cutting with my 120cm kaufmann cutter and it was ok but it was not save brackage on the end. so i decided to use only wet cutting. it takes more time (15l water for 1 tile needed) but it is 100% safe and the edges are perfekt. for this projekt i bought a new drilling machine. my other one is limited on 40cm wide. for the 45degree cuts in the niche i use my little wet saw. crazy, such a machine park for only a shower!
jonnyc
CREMA11.jpg crema.jpg CREMA6.jpg CREMA3.jpg CREMA4.jpg CREMA2.jpg CREMA 5.jpg CREMA5.jpg CREMA9.jpg CREMA10.jpg CREMA 8.jpg terracing job including pool surround, bench seating and water feature.
i brought this brabazon limestone in from france .approx 500 sq mts.
main terrace 400 x random length x 30mm thick.
all steps cuts cut and finished on site from running lengths.
this stone is not that hard but amazingly durable. I have never had any real problems with this stone over last 15 years even with t he 3 or 4 really bad winters of last five years.
R
rainsco
hi ishi, the tiles are 1000x1000mm but most of them cut to 850mm.
finished the tiling last week. the floor is cementscreed colorless sealed with epoxy. the ceiling is face concrete.
today i tried out the raifix system. (search google for videos)
it was a little restauration job. the whole house get new paint and this wall is a never ending problem. so i said to the customers i try a new mechanincal fixing system and tile this problem-wall. i use ardex X32 and the fixed the last set sideways. so its only one tile with is not mechanical fixed.
what do you think about this system? the dealer says i´m the first one who ordered this.
Status
Reply to Show Us YOUR Work Thread - Tilers Pictures in the Tiling Work Showcase Forum area at TilersForums.com
  • Locked
  • Suggestion
I spend some time in doorways. TJ's Doorway Mosaics for McKenzie Shop Front
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
Morning All! I thought it was about time to start a new Good Morning Thread. The old thread can be found HERE but is quite long so not as easy to find specific posts. So tell us what you are up...
Join The Tile Association and Get Noticed Some time ago joining The Tile Association may have got your tile business noticed, but it wouldn’t have helped your website much, as the Tiles.org.uk...
  • Article
Morning all. Dan asked me to post up a thread about our training centre which he can then use for feedback. We have been established in Newport, South Wales (just across the bridge from Bristol)...
