budbecks
Hi all.
I have a problem with some small mosaic glass tiles. The glass mosaics are 8mm thick and are small 15mm x 15mm. I have tiled a bath base and complete shower with them. I have also tiled the entire bathroom including floor with 300mm x 600mm porcelain tiles. The customer brought all the materials through the local building merchants and so they supplied the correct grout and flex adhesive etc.
The trouble i have is the grout they supplied is BAL wide joint 2 - 12mm grout. All of the joints are 2.5mm and the mosaics are 1-2mm obviously. I have managed to grout all the large porcelain tiles but the mosaics are going to be a pain in the neck using wide grout. I find it horrible to use and very sharp and very gritty. I've used it before of wide grouting and its great but rubbish for mosaics.
The customer will probably only use BAL as that what the manufacturer recommends but is there a better grout for mosaics.
I need to grout about 9m2 of 15mm x 15mm x 8mm glass mosaics. How much/many kilos of grout would i need to complete the job.
If any one can help i would be very grateful and would save a lot of swearing 🙂
Thanks in advance
BB
Thanks in advance
BB
