Grouting advice needed for small glass mosaics
Hi all.
I have a problem with some small mosaic glass tiles. The glass mosaics are 8mm thick and are small 15mm x 15mm. I have tiled a bath base and complete shower with them. I have also tiled the entire bathroom including floor with 300mm x 600mm porcelain tiles. The customer brought all the materials through the local building merchants and so they supplied the correct grout and flex adhesive etc.
The trouble i have is the grout they supplied is BAL wide joint 2 - 12mm grout. All of the joints are 2.5mm and the mosaics are 1-2mm obviously. I have managed to grout all the large porcelain tiles but the mosaics are going to be a pain in the neck using wide grout. I find it horrible to use and very sharp and very gritty. I've used it before of wide grouting and its great but rubbish for mosaics.
The customer will probably only use BAL as that what the manufacturer recommends but is there a better grout for mosaics.
I need to grout about 9m2 of 15mm x 15mm x 8mm glass mosaics. How much/many kilos of grout would i need to complete the job.
If any one can help i would be very grateful and would save a lot of swearing 🙂
Thanks in advance
BB
I have just grouted glass mosaic with microflex, all good apart from the residue on the tiles, can i use LTP grimex or LTp grout stain remover, and are mapie adhesives and grouts better than bal, everybody seems to sell Mapei now, my tile warehouse only sell Bal, where you can buy mapei at BQ if you run short
Well what an experience !!
All i could get is superflex in 3.5kg bags. So i brought 3 bags. Then another 3 bags and was still short so had to get another. I needed 7 bags in total a £11.50 a bag £80 in grout for 9m2 of mosaics !!
Must admit is does look nice and there no way i could have done it with the wide joint they supplied.
The mosaics had polished stainless steel as well dotted around. In total there must be getting on 3000 polished stainless steel 15mm x 15mm mosaics and everyone has a protective sticker on so the grout doesn't scratch it !!
I've had to take some off to fit the shower screen and Silicon the corners etc and it takes forever. It'll give them something to do mind !!
Im guessing hot water would aid removal but haven't tried.
Charcoal grout is pretty good stuff as well. get absolutely everywhere. I've only ever grouted floors black not walls or mosaics wow black everywhere.
Anyway after i finally grouted and siliconed all up it does look pretty good and im happy with the end result. I think they were too... i hope 🙂
I'll post some pictures when the plumbers put the sanitary ware in and electricians done his bit.
Hmm. Wish I'd seen this thread last week. I ordered some glass mosaics, and took the supplier's advice and ordered BAL superflex. The tiles are for the kitchen. The datasheet for superflex suggests that it is entirely unsuitable.
I've not grouted yet. Should I go and get myself some microflex? I am grouting tomorrow, so will have to go to topps where it is £17 for a 3.5kg bag of white (or £23 for a 3.5kg bag of ivory?!).
Thoughts?
I would use Mapei ultracolour plus or Arduflex fs, are you near a CTD branch,
as they supply all three brands
hmm suppliers recommending bal i wonder why oh yea cause its expensive and suggesting wide joint grout for wall mosaics:mad2:
Thanks guys. But is superflex unsuitable, or just not as good as microflex? Bearing in mind that the tiles I bought were described as kitchen tiles? If it is entirely unsuitable I will tell the supplier - in the past, having people on this board saying that what the supplier has done is unsuitable has made a big difference in discussions with suppliers!
Reading the specs for superflex it does say that its suitable for shower with a clause to say that if the shower is a power shower or has body jets then an epoxy grout should be used.
budbecks,
Dave H,
budbecks,
Dave H,
