grouting slate
not a case of leaving it dirty, its a case of wether u use plenty of clean water and chemicals in water to clean it is still a lengthy process compared to other tiles!
Getting to lots of clean water when cleaning down is the answer which of course removes the need for bottles of cure.:yes:
yes but what i find is no matter how much clean water i use there is always the need to use some sort of chemical after time to fully clean all those liittle ridges. i dont like to over do it with the water so soon after grouting as it tends to whiten a grey grout.
Then try slate seal from lithofin and let me know how you get on m8 should solve your problem as does away with clouding pretty much.
tiler
grouting slate
zohar1,
Ric,
zohar1,
Ric,
