Need a new grinder blade.
In that case @ATSDiamondTools .....I will wait until you have stock and buy a couple of yours. Did you say yours is the equivalent of the green or red? & what is the difference between the two?
No idea as I'm not sure what the difference is between the green and red. It could simply be different diamond quality and content (which is usualy the difference between economy, standard, premium and super).
It could be something as simple as blades from different factories as this design won't be patented by one particular producer.
As we manufacture in relatively low volume we produce most of our blades at super level as the difference between economy and super can sometimes be as little as US$ 3.00. So if we're ordering a production run of 1000 pieces it's not a massive expense.
However someone like Bosch buy in production runs of around 1 to 5 million pieces at a time, so it can be a substantial amount of money. So that's why some of the big brands don't perform as you would expect.
Companies like Montolit or Marcrist are just bigger versions of us, they run (relatively) small prodction runs when compared to Bosch or Dewalt etc, so they can produce a higher quality blade without a massive capital outlay.
I ended up getting the Akumax from CTD.
Always nice when part timers update their threads! Too many holidays, too much time with grandchildren, too much drink and too much excitement with Haway the Lads!
Not enough forum time - you need to get a life!
I used mine to cut some urban cement (Johnson's ceramics from b&q) yesterday, soft white biscuit. The blade was pants!
Cuts porcelain brilliantly but it's rubbish on ceramics.
Dave,
One Day,
Dave,
One Day,
