There is no advantage!What is the advantage of using tub adhesive which typically is spread at a 3mm thickness over cement adhesive which I was trained to use at a thickness of 8mm. I was told once the tub is open it starts to go off and a slow/amateur tiler would be better with cement adhesive. Discuss!!
When you say 3mm you surely don't mean a 3mm trowel . Cement adhesive even if slow set will go of quicker than air drying ready mixWhat is the advantage of using tub adhesive which typically is spread at a 3mm thickness over cement adhesive which I was trained to use at a thickness of 8mm. I was told once the tub is open it starts to go off and a slow/amateur tiler would be better with cement adhesive. Discuss!!
That's actually quite funny Tom. 😛Ooooo I forgot another great advantage................
Frisbee lids............
Bal Wall were the best ever and nigh on perfect.
