dot and dab
Do you skim any adhesive on the back of the tile or the wall or do you put blobs all over the back of the tile then stick it on the wall ?
Anything other than plasterboard I will prime. When it comes to laying, I'll wipe the wall over with a damp sponge to remove any dust and also the backs of all the tiles. I'll apply dots to a tile in a set formation (not randomly all over the back of the tile) making sure that there is more adhesive on the parts of the tile where I know the wall is out. You can tell whether or not you have enough adhesive on the tile as soon as you place it on the wall. It should take real firm push and a rub (agitates the adhesive) to get the tile flush with the others. If you're not used to tiling this way, of course it's going to take a longer, but for me I do it most of the time so I'd obviously be a lot faster at it. There is no question of the quality of adhesion I get when I tile. Like I've said, the odd occasion I've had to take tiles off, like if one has kicked out or I've forgotten to space it before it sets, it's taken most of the board with it or on solid walls, I've had to smash it then chisel it off with the SDS.
All I asked was how you key the adhesive to the substrate......and you fly off on one of your little rants..lol
As others have said they would at least skim the substrate first before fixing the tile.....think I shall bow out of this one and leave you to it.....good luck...🙂
There is a massive difference between dot and dabbing and solid bedding a tile. When you next the could you take some step by step pics of your process. Then a ballanced Veiw can be given.
I can't remember the name of the German guy ( amazing tiler) who used to cone on here. But he used to solid bed all the time. This was achieved by bedding the tile and wall, fitting the tile, then removing to see any voids. Re bedding, and lining up. He pretty much had 100% coverage.
Well in that case, I apologise for snapping the way I did. Priming is standard practice and its not the application that primes the surface providing a key, it's the preparation done beforehand. Come on, it's not hard to get tile adhesive to key, you must know this 😉
My method of dealing with low areas on the wall is to comb the wall, and comb the back of the tile also where needed, weather that is all the tile, half the tile, a 1\4 of the tile, whichever, and of course back butter the whole tile.
If more adhesive than that is required then really, it shouldn't be getting tiled, is should be prepared better. Its not unusual to have to use 10 or 12mm notch on the wall and the tile in certain areas. Same applies for floors and walls
Why does Mapei Pro flex have a maximum bed of 3-15mm then? It would suggest you can bed the tile out beyween those parameters would it not? Some of you are saying that you achieve 100% coverage, but time and time again when ripping out old tiles, I'm not seeing this "100%" bed when tiles have been removed. I'm seeing not a solid bed, but lines and lines of adhesive on the wall. Its like the tile has been laid as light as can be, just about touching the combed adhesive without much spread at all. As long as the tiles are not going to come off the wall and there's a lot more adhesive on the back than not then in my opinion, there's nothing wrong. Look at what Antonio said and how they do it in Italy, not by British Standard. Are you going to turn round and say they are doing it wrong because its not the British way? 🙂
Fair comment and I apologise for my part. What I don't like about these forums is that people are telling others that this method is bad or is cowboyish. You can tell from the standard of someone's work wether a job has been done with pride or not. I posted earlier an article of a new new method of spot tiling which everyone has conveniently seemed to ignore. People don't like to admit that maybe sometimes they can be wrong and that's the problem. I don't want customers coming up to me telling me I'm doing my job wrong because they've been looking in a forum such as this! I don't use "5 spots" but how would they know that, they would just see me spotting the back of the tile and presume the worst. I'm going to write to the British Standards agency myself to express feelings on the matter, how far I get I'm unsure. I didn't intend to come here to cause trouble...
The article has nothing to do with what youre doing because its about a high performance epoxy adhesive, and its an Aussie article.
dot and dab
diamondtiles,
Qwerty,
diamondtiles,
Qwerty,
