Weight limit on painted plasterboard
Hi All,
We're currently looking at 600 x 300mm porcelain tiles for our bathroom. The majority of the room is currently painted skimmed plasterboard (which is attached to stud and exterior wall )
From reading other threads, it seems we may have some issue with the weight of the tiles?
Is there a link which shows the weight limit?
If our tiles will be too heavy, what options do we have ( please list all, even if they may be extreme).
Thanks in advance.
Plastered PB is 20kgm2 WITHOUT paint.
Unskimmed is 32kgm2
Hardibacker board 100kgm2
Tilebacker boards around 50kgm2 (manufacturer dependent)
Porcelain is approx 2.4kgm2 per mm
Adhesive and grout approx 4kgm2
Hi @3_fall thanks for the prompt reply.
What does the PB refer to in point 1?
What effect does it being painted have, is it that the weight limit will be reduced by the weight of the paint?
Regarding our options assuming we're going to have 600 x 300mm tiles which will be over the weight limit.
1. Remove all existing plasterboard and replace with new unskimmed plasterboard.
2. Overboard throughout with either hardiebacker or some other tile backer board
3. Go ahead and tile onto existing painted PB.
This tiling malarkey ain't half complicated, and I haven't even started to think about setting out / laying the tiles yet.
PB = plasterboard.
You shouldn't tile over paint, it can very easily debond from the wall, leaving you with a pile of tiles on the floor with paint stuck to the back.
You can overboard with a lightweight tile backer board like Delta board.
Or remove the paint, but that's still over the top really.
Or you can use a thin porcelain tile (4-6mm), after removing the paint.
This is the same problem I see all the time and there is no easy quick fix, everyone wants nice porcelain tiles instead of ceramics ofcourse. Best bet is to over board the lot, with plaster board or tile backer board, then tank the shower area
Overboard with delta board / wedi board / kerdi board (lightweight tile board) NOT hardibacker / aquapanel.
Easy to screw 6mm boards into studs using washers, but on dry-lined walls you'll need to dot and dab onto your existing walls, noting where the dabs are and drill through them afterwards into the block using some frame fixings, again with washers.
That's the only way I would tackle it.
Tiling Standards
Shooter999,
Perry,
Shooter999,
Perry,
