One Day
Comb adhesive onto the wall, fix the boards with screws into the studs and 6mm is fine.Are 6mm boards ok on walls, I thought 10mm was advisable
6mm on its own would be useless onto studs, but over boarding existing painted walls, it's effectively just facing the walls. I'd use a 6mm trowel just to prevent any dips and hollows.So you need to use adhesive even onto stud walls?
I assume you need to comb adhesive onto solid walls too rather than dot and dab ?
That's American Andy.It's suggesting you stick the board onto the wall with tile adhesive only, and you can use fasterners temporarily. I assume it means on to plaster
