How long to wait until tiling onto 75mm screed
A
ashurst
I am having wet underfloor heating installed on top of 150mm insulation. The screen will be approximately 75mm. I will be laying 10mm porcelain tiles. How long should I realistically wait until tiling onto the area as I am reading conflicting things.
I am hoping that 21 days should surfice
Leave 7 days after laying.
Commission ufh and put on low for as long as it takes to dry.
Sand floor to remove latience a few days after heating is turned on ( will set like rock if left any longer) this also helps drying times, a the polymers act like a plastic , trapping moisture.
When it's dry, turn off heating and tile.
sand and cement?
very deep for gypsum based. optimum for those is around 45mm i believe
Yeah doesn't mean it couldn't be though.
It's the most commonly used screed these days over UFH And builders as we know don't always follow the rules.
Could just be a fibre reinforced screed but Id want to be sure what I'm dealing with before laying anything.
In answer to the original question With UFH commissioned and running It's possible to dry it out in about two weeks
ashurst,
Geoff Thacker,
ashurst,
Geoff Thacker,
