Is This Tile Cutter Good?
Hi, I' going to tile my floor, just wanted to know if this tile cutter was really any good for cutting 600 x 600 x 10.2mm thick polished porcelain tiles, or do I need something with more power?
Compact XL Tile Cutter
Yes DIY. I also have a Big Clinker 2.
The Big Clinker will be fine for you. I'd also suggest a grinder with decent blade which shouldn't set you back more than £50, then make sure you get ear defenders and a good set of safety glasses. (dust mask is good idea too)
Obviously you can only cut outside, but with a bit of practise you will get far better results than you would with anything less than a truly professional wet saw.
theandroids,
theandroids,
theandroids,
theandroids,
