What is your preferred method?
Understood- shower pumps or processors aren’t temporary though. The house I’m working in at the moment has I beams on each floor. There are holes along each beam that you knock out with a hammer for services. In this instance push fit or press fit is the only option to get pipes through as notching isn’t permitted. I do agree though, it does devalue our trade.
Trust me though, if an OEM fitting fails on a shower unit, it will come back to you in the same way if a fitting fails under a floor
In cases like I beams or metal web joists there is not a choice so I will use it there, but it allows you to get from point to point with minimal fittings.
But for altering existing copper pipe work I much prefer the old well tested way, it’s no slower really, even on rad alterations, I haven’t drained a heating system in years and solder on the pipework with a cork and carrot.
Absolutely I prefer end feed too.
Yes I bung open vented systems too. Amazing that there are still people out there who don’t know about it.
The thicker the ply the better ,then ditra,everyones own choice ,as long as they all work
Thanks for the input fellas
I thought that this would be a mine field.....and I think I've been proven right!
So I thought I would give the 22mm NMP a go as what I will spending in additional product I will be saving in labour.
However it seems like the stuff is harder to come by than Rocking Horse......(you get the picture)
I've managed to find a supplier so we'll see how it goes.
Please do come back and tell us how you get on.
Lakey,
Old Mod,
Lakey,
Old Mod,
