Preparation for shower tiling
Ollywest
Hi all
I have a new build extension and the bathroom has been lined with green plasterboard then skimmed by the builder, looking for any advice on preparation for tiling a shower area? Seems it would have been better for it not to have been skimmed, can the plaster be tanked or primed, or overboarded with hardie-backer? Tiles will be 30 x 90cm ceramic.
Any advice welcome.
Remember- MR plasterboard shouldn’t really be skimmed unless prepped with thistle bond it.
If the tiles are too heavy the walls shouldn’t be tiled and instead taken down or overboarded with a suitable tile backer board.
Keep in mind the minimum/maximum compensation of any potential shower screen if overboarding.
1) are you sure they are 30x90cm CERAMIC?
2) even if you tank the skimmed plasterboard it will not take the weight of tiles of that size - in line with B.S. - it is still only 23kg per metre sq.
3) best option is as above. Get back to studs and use waterproof boards such as Wedi or similar, tape all joins.
Good luck and enjoy the forum.
The tiles are called Boston grey and 10mm thick, I'm told they are ceramic but could be porcelain. Shower is 1400 x 900. I could remove the plaster board back to stud and replace with 12.5mm cement board?
Just checked prices and Jackoboard seems a lot cheaper than Wedi is there much difference?
No. Very similar.
Keep in mind that you need much tighter stud spacing when using a foam board. For arguments sake if the board is 600mm wide, you’ll need 300mm centres.
And of course all joints, abutments and screw/washer holes need tanking.
Tanking and Wetrooms
Ollywest,
Time's Ran Out,
Ollywest,
Time's Ran Out,
