Discuss Kitchen tiling: Doing corners with patterned tiles (square) in the DIY Tiling Forum area at TilersForums.com.
UK
Hi All,
I'm about to start my first tiling job (at home) and after thinking about steps have a few questions regarding corners (inner corner(s).
I have 5 msq area to cover, and my tiles are square, each box of tiles contains 5 different patterns, below is an image of the patterned tiles.
Q1: Should I start from the middle of the wall and go out to edges? This might end up with half a tile when it meets the corner, should I put a complete tile on the other side of the corner, or go for another half which would visually look like a whole tile going round the corner?
My thought is if I follow the rule of going from the middle on all walls, I could end up with strips meeting at the corner and not looking like it forms a whole tile as it goes round the corner, but visually this might not even matter? But im guessing in the world of tiling it defiantly does.
My other thought was maybe its better to start at the beginning of one wall with a complete tile and follow it all the way round the 3 walls, in this case I would get a complete tile look all the way around.
Q2: Because there are multiple patterned tiles, I would assume its a must to pattern match the tile in corners? If I go for working from middle out and end up with half a tile at the corner, the other half tile that connects to it on the other wall should match the same pattern.
Apologies for the basic questions, I have looked on youtube and forums, with no luck on my pattern issue in corners.
Thanks for any direction/advice on the above.
Boggs
1,118
Uk
I didn’t wrap the tile round on my kitchen, as I couldn’t get half a tile each side it made the corner tiles look longer and I preferred it this way visually. 5D7656FE-50C1-410E-BA70-BFFE2200C8DE.jpeg
UK
I didn’t wrap the tile round on my kitchen, as I couldn’t get half a tile each side it made the corner tiles look longer and I preferred it this way visually. View attachment 104778
Thank you very much for sharing, the tile and job looks superb. I've taken note here of what you have done in corner and most likely will follow the same idea.
P.s you literally couldn't have supplied a better response.
Boggs
1,118
Uk
The pattern should be followed around the corner.
That would annoy me every time I saw it!!
Ah well, won’t be inviting you for dinner then...
UK
Thanks all.
Ok sounds like I need to start from the center of each wall and work out to the corner.
This would mean the two tiles touching in the corner (same row) don't need to visually form a whole tile and two thin tiles touching will look ok.
The only way I can see to form a whole tile visually in each corner is to start at the beginning of one wall and work all the way around.
Waluigi
I think you get away with it as the right hand wall has a full tile in the corner, hence you have nothing to wrap around.
Unless of course you changed the layout on the right wall to wrap the pattern round but that’s beyond what I can see. I think it looks fine regardless.
Boggs
1,118
Uk
A few more for you. A3C64D4E-9FE4-47A3-99AB-570526D5600E.jpeg 0CED0F66-5AEC-4769-B7A9-4D8F5E341945.jpeg 39E37679-DA26-4A6D-AF6F-7EF50CA1130D.jpeg 9B7FC6E3-377C-4637-8830-F123C60B6BF5.jpeg 204125F8-9A9D-4581-A44F-75A8D664BE44.jpeg
The middle tile in the picture above wraps round, only just realised!
For me they look better random but that’s my personal choice and looked better with how my corners were working out.
Thanks all.
You don't need to have 2 thin tiles touching . Let's say you get that if you start with a grout line in the centre so move the tile over half a tile and have the middle of the tile as your centre point then you're cuts into the corner will then be at least over half a tile .
Time's Ran Out
I don’t know which DIY school of tiling you all went too but it certainly wasn’t on a construction site! Try getting away with not following the ‘pattern’ around the corners with an Architect or designer and see if you get paid. Any decent clerk of works will condem those corners ( but no doubt the customer will stick a microwave in front).
Perhaps aesthetics don’t come into your setting out or is it being lazy.
Now there’s something for all you tilers to disagree with !
Waluigi
I don’t think it’s a black and white argument, there are grey areas.
For example, wrapping a tile around a wall should really be done in the correct manner whereby it’s a true wrap of the tile, so it follows how a complete tile would wrap around the wall, not an elongated tile. That said, it’s not always possible to do that. Wrapping a tile around so the pattern follows yet having an unusually long tile one end would look wrong to me. Likewise having a very large cut or almost complete tile in a corner and a slither the other side would also look wrong.
As with all of these things, you make the judgement for each room and each room has its own set of focal points.
I do agree that in certain situations, not wrapping a pattern round a wall would look daft- if you have two half tile cuts in adjacent corners for example.
I don’t have fixed ideas with these things though. Every tile and every scenario is different. Sometimes you have to apply an artistic license to these these.
Waluigi
Gotta agree. It’s not a proper pattern wrap. It’s the same tile being followed around the corner. The pattern doesn’t wrap so in this instance I would’ve chosen a different tile on the adjacent wall.
That said, I might give a completely contradictory comment if it were a different tile. Every job is different. Unless you’re on a site doing the same tile in the same kitchen x 50 :D
Time's Ran Out
Well it certainly showed who the real tilers are - but that’s what this forum is for - all skill set levels - and plumbers!
I suppose you don’t follow a herringbone or hexagonal tile around a corner either because that would take too much setting out around a room. Just come out with any old cut and tell the customer that’s the best you can do.
Reply to Kitchen tiling: Doing corners with patterned tiles (square) in the DIY Tiling Forum area at TilersForums.com
  • Question
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
