Kitchen tiling: Doing corners with patterned tiles (square)
Hi All,
I'm about to start my first tiling job (at home) and after thinking about steps have a few questions regarding corners (inner corner(s).
I have 5 msq area to cover, and my tiles are square, each box of tiles contains 5 different patterns, below is an image of the patterned tiles.
Q1: Should I start from the middle of the wall and go out to edges? This might end up with half a tile when it meets the corner, should I put a complete tile on the other side of the corner, or go for another half which would visually look like a whole tile going round the corner?
My thought is if I follow the rule of going from the middle on all walls, I could end up with strips meeting at the corner and not looking like it forms a whole tile as it goes round the corner, but visually this might not even matter? But im guessing in the world of tiling it defiantly does.
My other thought was maybe its better to start at the beginning of one wall with a complete tile and follow it all the way round the 3 walls, in this case I would get a complete tile look all the way around.
Q2: Because there are multiple patterned tiles, I would assume its a must to pattern match the tile in corners? If I go for working from middle out and end up with half a tile at the corner, the other half tile that connects to it on the other wall should match the same pattern.
Apologies for the basic questions, I have looked on youtube and forums, with no luck on my pattern issue in corners.
Thanks for any direction/advice on the above.
So you are spot on, I'm going to try and remove the cooker hood and chimney so I can tile behind.
Are you saying use the center of the hob as the middle?
Find the centre line down from the hood and use that as your centre.
The pattern should be followed around the corner.
That would annoy me every time I saw it!!
Ah well, won’t be inviting you for dinner then...
Thanks all.
Ok sounds like I need to start from the center of each wall and work out to the corner.
This would mean the two tiles touching in the corner (same row) don't need to visually form a whole tile and two thin tiles touching will look ok.
The only way I can see to form a whole tile visually in each corner is to start at the beginning of one wall and work all the way around.
DIY Tiling Forum
diy_dude,
Dan,
diy_dude,
Dan,
