My 1st Job Which one? - DIY Kitchen Tiling Job :)
Good Afternoon.
Looking at taking on my first DIY Tiling job in our kitchen. I will be covering roughly 3.5m2 and will be using a 20x10cm ceramic tile (ToppsTiles Matrix White tile).
Watched various online videos etc but i'm confused which adhesive i should use. Was initially set on a ready mixed one for ease etc but after reading many reviews on different sites im now even more confused than before.
I just wanted something that was easy to work with, wasn't going to set to quick as this is my first time tiling.
I have borrowed this picture from another thread (sorry to the owner), basically our kitchen is identical so its mainly a splashback but we don't have the small upstand anymore.
Any recommendations please would be appreciated.
Ok , is the paint porous ? , does it wet up when you wash it ?
I have no idea, i haven't tried/didn't know to test it to be honest. All i know its probably a trade type emulsion.
When you say 'wet up', what do you mean? can it be wiped clean?
I mean does it darken when wet. If so then it’s porous and needs to be removed , some can simply be scrubbed off with a scotch pad.
it’s not really advisable to tile on emulsion.
As for adhesive choice , then the one Julian mentioned is ok for that size tiles , follow instructions on the bucket
Ok thank you, will check tonight. Around the cooker/hob area it does have staining from oil etc which i was going to lightly sand/key up prior to fitting the tiles anyway. Then would it be beneficial to clean with sugar soap?
Or do i need to fully remove all paint to be 100% sure.
My 1st Job
Faithfull,
Steve6690,
Faithfull,
Steve6690,
