Discuss Cutting advise for 38mm Yorkstone in the Tiling Tools area at TilersForums.com.
Hi all, just wanted to ask for some advice please as to best option for cutting 38mm Buff Yorkstone steps and slabs.
I will be cutting 1500mm steps length ways for the risers along with 600x600 slabs.
I was looking at hiring a Flex CS60 with rails but not sure if that will do the job or if there is a better option, I would like to make as least mess as possible if there such a option, also there isn’t much space on site.
Many thanks in advance!
These are the steps:
Dave
Subscribed
389,894
1,000,000
Co.Durham
Hi, thanks for the reply, we do have one but am concerned won’t be able to get that straight cuts along the steps as they are 130cm long hence I thought having a guide rail with the Flex saw would be a better option?
Cuts edges would go to the back. Or are both edges on show. ?
Do you have any pics of your project?
Hi, back and one side are covered but right side will be visible.
Reply to Cutting advise for 38mm Yorkstone in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
