Tiling over screed/plywood floor with height differences.
Hi guys.
Im a carpenter who has tiled a fair few floors over the years as i fit a lot of kitchens.
I have turned up today on a job and have been offered the floor tiling with ceramic tiles.
Its a big area (64sq/m) but a third of it is a new extension with a screeded floor. There is then a 12mm expansion gap before it hits a plywood floor on joists for the rest of the area.
To compound the problem even more the screed is 10 -12mm higher than the ply but only in some areas being level in others.
Can somebody who knows better than me advise on the best practise to overcome these issues and the best way forward.
The tiles are 600x300 and the floor has piped underfloor heating.
Its a situation i have not come across before.
All help is very appreciated so thanks ahead.
Hi guys.
send pictures
I will take some today and post later, thanks.
Hi, further investigation has revealed a chipboard floor with 6mm ply scewed on top
what about the screed, is it level along the timber floor?
Some places yes and some places its as much as 12mm higher than the wooden floor.
Am i right in thinking that even if i got the two floors level and then tiled over the two substrates the tiles will crack and that an expansion gap is necessary where the two floors meet.
If the timber floor is level and the concrete is up and down, grind off the bumps. You can use a 7'' angle grinder with a diamond cup and a shroud to do so.
There will be a movement between the two floors. Out of the question.
Only the almighty knows if there will be cracks in that floor. Aren't you going to use an uncoupling membrane on top?
If the customer wants an expansion joint. Then do it and it is safer.
Most don't like the idea of having extra joints/trims on the floor.
Johnny,
Tile Marble Granite,
Johnny,
