Discuss Advice needed for mosaic splash backs in the DIY Tiling Forum area at TilersForums.com.
Hi,
I'm looking for some tips on installing mosaic sheets, they are going to be installed in a kitchen as spashbacks. I'm looking for advice on planning and how to cut them in around sockets. Also how to get them flat to the wall without them dipping and bowing out. I think they are glass material but will update when I seen them as I'm installing them for my son,
Regards Rob
MTiler
Just use a decent white cement based adhesive (do not use a rapid set) and they shouldnt slump, if you find they are then just cut the sheets in half. When going around sockets etc just cut sheets into sections, no need to struggle with a whole sheet. The wall needs to be completely flat you cant use adhesive to pack them out as youll only be using a small trowel and itll get messy. Trowel size will depend on size and thickness of mosaics. 3 or 4mm are common sizes.
Backer sheets arent worth the hassle, the adhesive will need to go though the mesh and make contact with he mosaics.
Use a grout float to pat the mosaics flat.
Sharon
These are the mosaics glass and stone.
dynamictiling
578
glasgow
I have used these before and I can confirm you are in for a headache...
Alot of the mosaics are stuck on squint, slightly different sizes. I ended up sticking them on and going back with a Stanley knife to cut and fix the worst offenders. Best of luck.
dynamictiling
578
glasgow
Dynamic, how did you cut around sockets etc ?
Use a Stanley knife to cut all the 'whole' tiles out that work in cuts at the socket. Once you have stuck your sheet on minus the socket tiles, go back and Mark the socket tiles, cut them and stick them.
Thanks for advice, but whats best to use to cut the mosaics when finishing socket ?
Reply to Advice needed for mosaic splash backs in the DIY Tiling Forum area at TilersForums.com
Hi Guys, I had some mosaics installed the other week and seeing some very odd discoloration on...
Hi all, I'm due to install Fired Earth glass mosaics (*££!!) and am a bit nervous about safety...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Wiltshire
DIY Tiling Forum
    Votes: 5 5.1%
    Votes: 8 8.1%
    Votes: 6 6.1%
    Votes: 24 24.2%
    Votes: 14 14.1%
    Votes: 27 27.3%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.2%
    Votes: 18 18.2%
    Votes: 11 11.1%
    Votes: 5 5.1%
    Votes: 3 3.0%
    Votes: 0 0.0%
