Discuss Metal tile trim in the DIY Tiling Forum area at TilersForums.com.
Hi All
I'm looking for some nuggets of wisdom please.
I've used the plastic rounded edge trim before and got great results without much thought.
I've gone for metal square edged stuff this time and I can't figure out what to do here.
The left hand wall at the tap end of the bath is going to be fully tiled, but around the corner, where it's painted white, I was only going to tile half way up.
So the trim sits proud of the wall on the external corner to accommodate the rough edges on the bottom half. And the I guess I just have to deal with it sitting proud at the top, where the wall is painted. Unless anyone has any clever ideas?
Thanks a lot
Bond
528
Highland
Aye that’s right, don’t know how it would look, try it out and see.
or you could try out , trim corner to half height, small shelf on top then continue trim above in line with corner.
[automerge]1599164240[/automerge]
So I'd have double trim at a 90 degree angle to each other on the bottom half?
[automerge]1599163756[/automerge]
Ah, no. I know what you mean. Will try setting that up tomorrow. Perfect. Thank you 😁
Aye the trims would be back to back.
Reply to Metal tile trim in the DIY Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, after watching so many instructional videos and planing, I just can't understand how to...
First time tiling, lots of mistakes, but most of them have been resolved in a timely fashion so...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Evening, Hope this post is in the correct section. If not, please feel free to move! I'm...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Tamworth
What member type are you?
  1. DIY Wall and Floor Tiler
Metal tile trim
DIY Tiling Forum
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
