Discuss Water Damaged Old School Shower Repair Job in the America Tile Forum / Advice Board area at TilersForums.com.
My last Old School Shower Repair/wet room conversion. It was leaking in the basement to the point where the customer had to put a bucket underneath the drain to collect the water, 100% waterproofed. Flat Rock, MI
Your recent project tackling the shower repair and wet room conversion sounds like quite the endeavor! Dealing with a leaking issue to the point of needing a bucket in the basement must have been challenging, but it's impressive that you managed to achieve 100% waterproofing. Your attention to detail and commitment to ensuring the longevity of your work is commendable.
Looks like no one likes the ''water damage'' topic
You caught this one too. New build. Sloppy. No waterproofing, double tile on top, worse under everything
walls weren't much better no coverage, I redid floor and bench, waterproofing, builder did walls but I watched like a hawk, and provided subcontractor the tools and waterproofing. 2-3 years later no issues
Good thing you fixed it and no longer leaks. I like the marble slab niche.
Here's another Old School Shower Repair done for a customer of mine in Brownstown MI. This shower was leaking downstairs to the room below while the shower was in use.
The customer complained about some missing grout on top of the shower curb potentially causing the leak. It turned out the shower pan liner was cut and nailed down several times, staples everywhere inside the shower, black mold on the drywall causing the water leakage. The ladder mesh throughout the shower and the stainless-steel bolts on top of the drain were rusty contaminating the shower pan liner.
Rotted old school shower leakage.jpg Rotted old school shower.jpg Rotted away old school shower.jpg Rotted shower.jpg Rotted timber.jpg Rotted pan liner.jpg Rotted shower liner.jpg Rotted Shower repair.jpg Rotted box.jpg Rotted old school drainage.jpg
The shower was fixed, converted into a wet room and 100% waterproof.
Fixing these showers takes lots of patience, time consuming, and pain in the back.
These old school showers are the number one selling showers in North America, available on the shelves at any local building supply store, very cheap to buy and the number one builder's choice. In the long run you get dollars back, as they fail in some way or another.
Shower repair (2).jpg shower repair mortar bed.jpg Shower repair waterproofing.jpg Shower repair tiling.jpg Shower repair-boxed tile.jpg Shower repair-tile job.jpg Shower repair-tiling l.jpg Shower repair-tiling.jpg Shower repair job.jpg
Reply to Water Damaged Old School Shower Repair Job in the America Tile Forum / Advice Board area at TilersForums.com
  • Sticky
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
I have installed a wetroom form (the style below). I have removed the floorboards and lowered...
USA Tile Forum Popular
America Tile Advice Trending
Brownstown, MI. USA
Website
https://brownstowntilerepair.com/
What member type are you?
  1. Professional Wall and Floor Tiler
Business Name
Tile Marble Granite
    Votes: 9 6.0%
    Votes: 14 9.4%
    Votes: 11 7.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 2 1.3%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
    Votes: 7 4.7%
