Water Damaged Old School Shower Repair Job
My last Old School Shower Repair/wet room conversion. It was leaking in the basement to the point where the customer had to put a bucket underneath the drain to collect the water, 100% waterproofed. Flat Rock, MI
Your recent project tackling the shower repair and wet room conversion sounds like quite the endeavor! Dealing with a leaking issue to the point of needing a bucket in the basement must have been challenging, but it's impressive that you managed to achieve 100% waterproofing. Your attention to detail and commitment to ensuring the longevity of your work is commendable.
Looks like no one likes the ''water damage'' topic
You caught this one too. New build. Sloppy. No waterproofing, double tile on top, worse under everything
walls weren't much better no coverage, I redid floor and bench, waterproofing, builder did walls but I watched like a hawk, and provided subcontractor the tools and waterproofing. 2-3 years later no issues
Here's another Old School Shower Repair done for a customer of mine in Brownstown MI. This shower was leaking downstairs to the room below while the shower was in use.
The customer complained about some missing grout on top of the shower curb potentially causing the leak. It turned out the shower pan liner was cut and nailed down several times, staples everywhere inside the shower, black mold on the drywall causing the water leakage. The ladder mesh throughout the shower and the stainless-steel bolts on top of the drain were rusty contaminating the shower pan liner.
Rotted old school shower leakage.jpgRotted old school shower.jpgRotted away old school shower.jpgRotted shower.jpgRotted timber.jpgRotted pan liner.jpgRotted shower liner.jpgRotted Shower repair.jpgRotted box.jpgRotted old school drainage.jpg
The shower was fixed, converted into a wet room and 100% waterproof.
Fixing these showers takes lots of patience, time consuming, and pain in the back.
These old school showers are the number one selling showers in North America, available on the shelves at any local building supply store, very cheap to buy and the number one builder's choice. In the long run you get dollars back, as they fail in some way or another.
Shower repair (2).jpgshower repair mortar bed.jpgShower repair waterproofing.jpgShower repair tiling.jpgShower repair-boxed tile.jpgShower repair-tile job.jpgShower repair-tiling l.jpgShower repair-tiling.jpgShower repair job.jpg
Featured Threads
