Guest viewing is limited
Discuss 100% refit advice in the UK Tiling Forum area at TilersForums.com.
biffo17
hi my 1st post , im doing a 100%refit on my bathroom
all plaster is off ,all lath and plaster is off,its all being re tiled ok
a shower bath is going in ,this is where the bare brickwork is ,250 hardiebacker is going direct to wall /adhesive and screwed
the remaining walls all studwork i intend to use the 12mm moisture resistant plasterboards
the floorboards are up ,18mm ply going down 250 hardiebacker on top of this ,ahdesive and screwed
does this sound ok ??
im not doing the tiling !!!
horses for courses ,me thinks
doug boardley
I'd use the 500, (12.5 mm as opposed to 6mm) or even 12.5 mm plasterboard (dot and dabbed) with a tanking membrane.
doug boardley
not yet doug er indoors not decided YET !!!!
ill know tomorrow thanks again
here's the weight bearing guide for you biffo (courtesy of Oli's bible)
Substrate weight ratings
A common question, how much weight can my wall support, here are the reccommended max weight ratings in KG / m2
Plaster Skim on Plaster Board........20KG
Skim and Set Plaster...................28KG
Plaster Board.............................32KG
Sand and Cement.......................40KG
Cement Backer Board..................55KG
Hardibacker Board.......................45KG
Lightweight Tile Backer Board........40KG
Glass Reinforced Cement Sheet.....50KG
Gypsum Fibre Board.....................40KG
Remeber to factor in the weight of the tile / m2 AND adhesive and grout
Grout.........2KG / m2
Adhesive....4KG / m2
Reply to 100% refit advice in the UK Tiling Forum area at TilersForums.com
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
Hello, looking for advice and what to do next. Have had main bathroom installed via a local...
100% refit advice
