Discuss 16mtr, 600 by 600 porcelain kitchen floor on ply ? advice please ! in the British & UK Tiling Forum area at TilersForums.com.
2020Tiling
Re: 16mtr, 600 by 600 porcelain kitchen floor on ply ? advice please
slc the whole floor then tile!!don't bother with ditra..... imo
Thanks ! but iam getting mixed views on this ? slc b4 ditra or after and slc ? or no ditra and slc only ? what is the correct method to ensure a 100% correct fix thanks!
Andy Tiler
1,043
manchester
Iam totaly confused ?? Help!
Terry if the floor is uneven then using 600x600 tiles will be a nightmare!the floor needs to be flat!so screed the floor flat with fibreplan and tile it. as long as the floor is rigid and stable you will be fine.you don't need ditra!! imho sorry for confusing you ;)
Tony73
1,233
acton w3, london
I,ll tell you, 10 years ago i did hallway with 300x300 nero granite tiles straight on ply. after 7 years floor was still solid, not even tiny crack in grout. But now allways use ditra. So it's up to you how you want to do it :thumbsup:
Protilers
from a technical standpoint on the photos provided you should:
1. level the entire floor with a good quality SLC (fibre reinforced would be a preference for me!)
2. lay a decoupler across the entire area and then tile........
but because the area is sooooooo small i would lay a simple (inexpensive) crack iso membrane like "maptex" or "mapnet".... then screed with a good quality SLC and tile away...........(maptex is a fibreglass roll and mapnet is like underfloor heating without the wire!)
best wishes
Lee.
bugs183
I've spoken to Bal and Schluter about this very issue and got two different answers, one said Ditra onto ply then level, the other said level on the ply then then Ditra.
In my opinion why level onto ply and then Ditra, if you need an uncoupling membrane because you are using ply then get the ditra in first.
This one is down to you matey, there are no fixed rules here!!
Reply to 16mtr, 600 by 600 porcelain kitchen floor on ply ? advice please ! in the British & UK Tiling Forum area at TilersForums.com
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
